This command configures the LAG bandwidth mode as either cumulative or master-port only.
| all | All the ports in the switch. |
| port_list | Port list separated by a comma or - |
| cumulative | Use bandwidth of a single port, plus a percentage of bandwidth of every other LAG member port in the group. |
| single-port | Use bandwidth of a single port only for the entire LAG. |
| percentage | Percentage of bandwidth of each LAG port to be added to master port bandwidth. |
Single-port.
If cumulative mode is selected, the percentage is also configured.
This CLI command displays bandwidth information of an MSRP port.
# show msrp ports bandwidth
Port Port Class Delta Maximum Reserved Available
Speed Effective
5ab 0 M A 75.00% 0.00% 0.00% 0.00%
B 0.00% 0.00% 0.00% 0.00%
*21ab 1000 M A 75.00% 75.00% 0.00% 75.00%
B 0.00% 75.00% 0.00% 75.00%
Flags: (*) Active, (!) Administratively disabled,
(a) SR Class A allowed, (b) SR Class B allowed.
This command was first available in ExtremeXOS 21.1.
This command is available on platforms that support the AVB feature pack license and have it installed. For complete information about software licensing, including how to obtain and upgrade your license, and which platforms support the AVB feature, see the Switch Engine v33.1.1 Licensing Guide document.
